• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk DWF Viewer
    Active Member
    3DDWF Viewer API "Is it possible" questions
    113 Views, 11 Replies
    06-03-2005 07:19 AM
    Good day!
    Is it possible to change the color of object?
    Is it possible to get some object identifier, which is defined in autocad2006 (parameter, attribute, etc.)?
    Is it possible (i guess no but in future builds... may be...) to crosscut all objects in view like ModelPress does?
    Thanks!
    Please use plain text.
    *Ben Cochran
    Re: 3DDWF Viewer API "Is it possible" questions
    06-03-2005 09:51 AM in reply to: sinm
    Using an unpublished API you can select an object, other then that you can't
    change the color.
    Using an unpublished API this is possible.
    This is on the wish list for future releases.
    Ben
    wrote in message news:4864680@discussion.autodesk.com...
    Good day!
    Thanks!
    *John Schmier \(ADSK\)
    06-03-2005 11:15 AM in reply to: sinm
    If you used the unpublished API's they may not be available or may change
    between releases. We do not publish these API's because they are not
    finalized and may change from one product release to the next. If you use
    these API's you may need to update your applications when the next release
    of the viewers comes out.
    "Ben Cochran" wrote in message
    news:4865022@discussion.autodesk.com...
    change the color.
    Ben
    Good day!
    Thanks!
    *Ben Cochran
    06-03-2005 11:22 AM in reply to: sinm
    Thank you John, I should have pointed this out.
    The 3D APIs WILL change in the next release.
    Ben
    "John Schmier (ADSK)" wrote in
    message news:4865121@discussion.autodesk.com...
    change the color.
    Ben
    Good day!
    Thanks!
    *Bob H.
    06-03-2005 11:55 AM in reply to: sinm
    Is there a way to get some "wish list" items added to the next API release?
    news:4865159@discussion.autodesk.com...
    Ben
    change the color.
    Ben
    Good day!
    Thanks!
    06-03-2005 01:53 PM in reply to: sinm
    Post them here, the designers pull items from this newsgroup and assess if
    they should be in the product.
    "Bob H." wrote in message
    news:4865206@discussion.autodesk.com...
    Ben
    change the color.
    Ben
    Good day!
    Thanks!
    Active Member
    06-04-2005 03:12 AM in reply to: sinm
    First of all, thanks a lot for the reply!
    Pardon. I'm still confused a bit. First of all - where can i grab that unpublished API? What is that - another active-x or just wrapper to existing autodesk controls?
    And one more question, the last one (sorry for inconvenience/offtopic): how can i add custom properties for a 3dsolid said so in autocad 2005,2006? Just i'm in need in quick start.
    *Ben Cochran
    06-06-2005 08:44 AM in reply to: sinm
    All the viewer APIs published and unpublished are shipped with the viewer.
    The difference is that Autodesk will change the unpublished APIs with most
    releases. Additionally, Autodesk not does encourage using the unpublished
    APIs and will likely not help you use them.
    The unpublished 3D API is in the EModelViewer.dll open it up in an OLE
    object browser
    (http://www.microsoft.com/windows2000/techinfo/reskit/tools/existing/oleview-o.asp)
    and you will see the methods on this API. The samples I posted are in C#.
    Are you looking for samples in some other language?
    I don't know much about publishing objects from AutoCAD, hopefully someone
    else can help with that question or you may want to ask in the AutoCAD news
    group.
    Ben Cochran
    wrote in message news:4865584@discussion.autodesk.com...
    autodesk controls?
    Active Member
    06-07-2005 06:16 AM in reply to: sinm
    no. i've compiled that sample. Good enough.
    *Bob H.
    06-10-2005 07:43 AM in reply to: sinm
    VB6
    I would like the API to...
    SimplePrint - Add a parameter for printing landscape. Most users have their
    printer set to portrait. It would be nice to be able to use SimplePrint and
    have it print landscape.
    Control visibility of all toolbar and browser items. E.G.; Browser -
    Views/Properties panes
    Next / Previous cache should be cleared when a new dwf is opened.
    Be able to customize built in toolbar to add a button and fire an event.
    A more complete API help file with examples.
    message news:4865367@discussion.autodesk.com...
    Ben
    change the color.
    Ben
    Good day!
    Thanks!
