• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Constructware
    New Member
    PO template changes not recognized
    114 Views, 1 Replies
    11-14-2007 12:26 PM
    I made changes to the Purchase Order template, but they do not show up when I preview a PO. I tried first in C:\Program Files\Constructware SQL\Templates. It did not recognize the changes. Then I went to Tools/Maintenance/Purchase Order Templates and selected a copy that I had placed on a network drive. It not recognize that one either. Where is it getting it from?
    Thank you.
    Please use plain text.
    Employee
    Re: PO template changes not recognized
    11-15-2007 09:16 AM in reply to: JerryECO
    Did you download an existing template from Maintenance/Data Maintenance/Document Templates, update it, and load it back in at the same location?
    Once you do that, you should be able to preview the document from the Document Templates module or the PO module after you select the template and save.
    There is a web video demo of how it document templates work in the Help file. If you are still having trouble I would contact Technical Support (800-892-0449).
