• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Constructware
    Contractor RFI
    513 Views, 1 Replies
    08-11-2009 09:42 PM
    Is it possible to edit Documnet Template for Contractor RFI Module.
    We need to change the Header for that.
    Employee
    Re: Contractor RFI
    08-12-2009 12:11 PM in reply to: adilkhatri
    To verify:
    When viewing a Contractor RFI Module document are you specifically needing to use a custom document template or do you need to change what Logo is appearing. If you need a custom document template this is not possible.
    The logo that appears by default will be the From Contacts Company Address Logo.
    Unfortunately, the Contractor RFI Module is limited in customization. No options are available to customize attributes or viewing options.
