• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Constructware
    Employee
    Constructware: Uploading Issue
    526 Views, 0 Replies
    07-14-2009 10:43 AM
    Issue: Unable to upload document
    Why: Necessary components didn't install
    Quick Solution: Change level of Reference
    Permanent Solution: add necessary components by logging into your PC as the computer admin
    Uploading documents to Constructware PC will use either an Active X component or a Java component. Constructware has the flexibility to allow us to choose which component PC will use when uploading documents. If you experience an issue where you cannot upload a document please do the following:
    File Director Module
    Add File Button
    You will receive a Add File Dialogue Box where you can browse to local files, close this window
    You will receive a Constructware Add File Dialogue Box
    Locate the field named: Levels of Reference What is the reference number?
    When level of reference is set to 0 your PC is using Active X
    When level of reference is set to anything other than 0 your PC is using Java
    If your reference number is currently 0 change it to 1 click Continue. This should install the java component. Close Window
    If your reference number is currently 1 through all change it to 0 click Continue. This should install the Active X component. Close Window.
    Now go back to original module and try to reupload document as needed.
    If during this process you are unable to change levels of references back and forth this will be due to components are not installing due to the security enabled within your PC network. Contact local IT department. Log into PC as computer admin and follow above steps.
