• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Constructware
    New Member
    rjatherton
    Bookmarks not showing
    752 Views, 2 Replies
    06-19-2010 10:23 PM
    I am unable to select or even view bookmarks when setting up a project in the 'Assigned Companies' module.  Because I cannot select a bookmark, then the information is not showing up in my reports & contracts and etc...
    Is there a setting in my user profile that would allow me to see/select bookmarks?
    I've attached a screen shot, in case that might help.
    Employee
    Re: Bookmarks not showing
    06-22-2010 01:36 PM in reply to: rjatherton
    It seems that you do not have the correct permissions for the Document Templates module.   In the help, Assigning Bookmarks to a Project, it states the following:
    • You must have at least View permission to Doc Templates to change the bookmarks, otherwise the bookmark field will be read only on the Team Members edit page.
    Have the adminstrator for your Constructware site update you permissions in the User Maintenance / Users module.  Have them filter for your name and select the radio button next to your name.  Click the Permissions icon (looks like a padlock).  Go to the Maintenance tab, and change the Document Templates permission to either View or Administrator.
    Hope this helps.
    Jeff
    Jeff Marsh
    Technical Product Manager, Construction Business Line
    AEC Solutions Group
    New Member
    rjatherton
    09-19-2010 06:05 PM in reply to: rjatherton
    Just to follow-up, for anyone finding this post, I did exactly as instructed and it resolved the issue.  Thanks.
