• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Buzzsaw
    when i am trying to open Buzzsaw from AutoCAD LT 2004 it is not opening, why?
    36 Views, 1 Replies
    06-15-2003 04:57 PM
    Whenever i am trying to open Buzzsaw from AutoCAD LT 2004 using open command i am not getting any response ,whereas it is working in IE.i am using demo versions of both. what is the problem?
    Please use plain text.
    *Sheppard, Scott
    Re: when i am trying to open Buzzsaw from AutoCAD LT 2004 it is not opening,
    06-15-2003 11:31 PM in reply to: devig
    The ProjectPoint client application can be invoked
    as a stand-alone EXE or from within Internet Explorer. It used to come with an
    ObjectARX (AutoCAD Runtime eXtensions) application referred to as the
    Mini-Client because it allowed you to do some of the functionality of the full
    client from within AutoCAD. I believe the mini-client went away in Buzzsaw 4,
    but they are working on bringing it back. Regardless, AutoCAD LT does not allow
    for programmatic AutoCAD Runtime eXtensions like AutoCAD. That is why AutoCAD LT
    costs less. I believe if you invoke ProjectPoint from the EXE or browser and
    select "edit" for a DWG, it will bring up AutoCAD LT. So you can run AutoCAD LT
    from ProjectPoint but not the other way around. Someone from Autodesk may have
    more current information.
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    Whenever
