• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Buzzsaw
    New Member
    unable to install buzzsaw sync
    897 Views, 8 Replies
    05-31-2011 12:09 PM
    When I try to install the Buzzsaw Sync utility (downloaded from the Autodesk web page today) it consistently fails.  I am trying to install it on a Windows 7 64 bit machine and I downloaded and ran the 64 bit version of the Sync install.  The error message that comes up is that the installer threw a "1619" - a screen shot is attached.  I was able to reproduce this behavior on my own Windows 7 machine.  Any ideas what might be wrong?
    Please use plain text.
    Employee
    Re: unable to install buzzsaw sync
    06-02-2011 12:53 PM in reply to: svalenta
    Please contact our Support team about this:  http://autodesk.com/buzzsaw-support
    Joan Allen
    New Member
    06-03-2011 07:16 AM in reply to: svalenta
    Joan,
    I filed a support ticket three days ago, but have not heard back from support.  I'm getting a bit frustrated.  Support ticket number is 00411493.
    Employee
    Re: unable to install buzzsaw sync (resolved)
    06-06-2011 04:28 PM in reply to: svalenta
    The Buzzsaw support team confirmed with me today that this issue has been resolved.  In case anyone else runs into this problem, here is a description of the problem and resolution:
    It was a problem with permissions on the local PC (a user needs admin rights on the target installation folder in order to install Buzzsaw Sync).  This issue can be resolved by moving the Sync installation file to a folder where a user has full access rights.  From there, just open the installation file and install Buzzsaw Sync.
    New Member
    mark.hughes
    04-05-2012 05:57 AM in reply to: svalenta
    I have also run into this problem and relocating the .exe to a folder with full permissions does not solve the problem.
    Employee
    04-05-2012 09:58 AM in reply to: mark.hughes
    Hi Mark,
    If possible can you contact our Autodesk Support desk at 800-892-0449.    When calling we'll be able to determine OS and effectively troubleshoot issue.    Its possible issue could be related to Windows settings for UAC or Protected Mode within IE.  Thank you
    Employee
    04-05-2012 10:45 AM in reply to: mark.hughes
    Mark,
    I am including Buzzsaw sync msi packages for both 32 bit PC's and 64 bit PC's.  I'm curious to know if you log into PC as admin can you install software with this msi package?
    Windows 32 bit system
    http://projectpoint.buzzsaw.com/!/download//BuzzsawSyncSetup-32bit-EN.msi
    Windows 64 bit system
    http://projectpoint.buzzsaw.com/!/download//BuzzsawSyncSetup-64bit-EN.msi
    Active Member
    05-07-2013 02:14 PM in reply to: james.l.bryant
    I am getting a different error when tyring to install Buzzsaw Sync.  I have been having issues installing Buzzsaw Sync onto my machine since December.  Our IT department and or inhouse Autodesk guru have been uable to figure out why it won't install.
    Everytime I try to install Sync I get the same error, see image.  We have placed the msi into a folder that had full admin privages, IT has logged in to try and install, gave me full admin rights for the day, turned off all anti-virus protections and still keep getting the same issue.  At first they thought it was an MSI issue but I have been able to install other MSI programs from Autodesk as well as other vendors.
    Does anyone have a solution to this problem?
    New Member
    mirai_syasin
    05-08-2013 07:55 PM in reply to: svalenta
