• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Buzzsaw
    Member
    Visibility in Dyanmic Blocks
    114 Views, 3 Replies
    09-20-2011 03:12 PM
    I’m trying to create a dynamic block that has multiple versions of the same element.  In this case I want to have a block of a tree, but give the user the option of selecting a different tree type.  I can get the block set up and it tests fine, however when I insert into a new drawing, the visibility grip selection does not show up and I cannot get the option to change to another tree type.  Any ideas?
    I'm using AutoCad 2012
    Please use plain text.
    Employee
    Re: Visibility in Dyanmic Blocks
    09-22-2011 11:35 AM in reply to: gwebster
    Did you mean to post this to the AutoCAD discussion group?
    New Member
    AlanBrady
    09-29-2011 06:36 AM in reply to: gwebster
    When I opened it I was asked to open in the block editor. I said no. But I couldn't find a block. The second time I opened it, I went into the block editor, tested it and it works. So I went to Open/Save and then 'save as' and called the block something else (Tree). Then it worked fine.
    Member
    09-29-2011 07:13 AM in reply to: AlanBrady
    Thanks for the reply,  renaming the block was the key.
