• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Buzzsaw
    *James, Wayne
    Viewing Photos
    184 Views, 2 Replies
    07-29-2003 01:07 AM
    Trying to find a solution for viewing photographs on Buzzsaw. Currently,
    photographs are not resized to fit within the available window in buzzsaw as
    they are in IE on its own. This forces a user to have to scroll left/right
    and up/down to see the entire picture.
    Any ideas as to how we can force the image to resize and fit into the entire
    window?
    Please use plain text.
    *Smith, J. Daniel
    Re: Viewing Photos
    07-29-2003 03:41 AM in reply to: *James, Wayne
    It looks like the image resizing functionality works a bit funky in IE;
    you'll see the same resizing problems if you create an HTML page containing
    an tag rather than viewing the image directly in IE. You can
    work-around this by using a height (or width) attribute on the tag
    with a value of "100%", this allows the images to resize in the ProjectPoint
    client.
    With some (considerable?) effort, you can use DHTML and ActiveX objects to
    generate the HTML dynamically so that you wouldn't have to create a separate
    HTM file for each image.
    Dan
    "Wayne James" wrote in message
    news:F1E055E6790A12583DD3075A57D8156E@in.WebX.maYIadrTaRb...
    as
    left/right
    entire
    > window?
    New Member
    didrby
    Re: Viewing Photos
    02-14-2011 06:38 AM in reply to: *James, Wayne
    Try this:
    Click TOOLS, and then PREFERENCES
    Under the FILE TYPES tab, click on RASTER FILES
    Then in the Drop Down box, select BUZZSAW VIEWING CONTROLS
    Then hit OK
    Seems to work ok on my version.
