• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Buzzsaw
    New Member
    decoart
    Slow switching between layers.
    85 Views, 1 Replies
    11-30-2011 03:41 PM
    When switching between layers, Zooming, or changing views my drawing will lockup for about 5 min and then I am able to work again.
    System is
    AMD Phenom Quad Core
    6GB ram
    Raid 10
    FirePro V4800
    Not sure what direction to take from here.
    Employee
    Re: Slow switching between layers.
    12-02-2011 05:15 PM in reply to: decoart
    You may have too many layers in the drawing.  AutoCAD drawings that have a large number of layer filters can affect system performance significantly. In some cases, you may not even be able to access the Layer Properties Manager. To remove layer filters from a drawing, use the FILTERS command.  (See http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8203173&linkID=9240617 for steps on how to do this.
    The excess layer filters alert is controlled by the sysvar LAYERFILTERALERT.
    0 Off
    1 When the Layer Manager is opened, deletes all layer filters; no message is displayed
    2 When the Layer Manager is opened, displays a message that states the problem, recommends deleting all filters, and offers a choice: "Do you want to delete all layer filters now?"
    3 When the drawing is opened, displays a message that states the problem and offers to display a dialog box where you can choose which filters to delete
    The default for the sysvar is 2 i.e. the alert will display only when the Layer Manager is open.
    Hope this helps.
