• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Buzzsaw
    Distinguished Contributor
    Copy user permissions between projects?
    627 Views, 2 Replies
    09-18-2012 10:22 PM
    I have a few dozen projects which need to have their folder permissions updated. If I update the permissions on one, is there a means to copy them to the other projects?
    As you can imagine, it will be a painful process to have to do this manually with each project having dozens and dozens of subfolders.
    Chad
    Please use plain text.
    Member
    Re: Copy user permissions between projects?
    09-20-2012 08:30 PM in reply to: Brausmith
    To prevent this in the future, can you create a template folder and then just clone it and the permissions should follow?
    Also, by creating permission groups and assigning a group to a folder should be faster than individual users.
    09-21-2012 04:18 PM in reply to: Phaeax
    A template folder structure does exist and is used for cloning new projects. The problem is that the permissions are now changing as team structures change. This then means all permissions on all project are now incorrect and need updating.
    Plenty of Groups are in use, and while this will make the updating quicker, it's still going to take a very long time.
    Chad
