• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Buzzsaw
    New Member
    Buzzsaw Synch does not synch when I am not logged on
    872 Views, 2 Replies
    05-15-2012 01:59 AM
    Hello!
    We are using Buzzsaw Synch on a server to which files are posted that need to be synched with Buzzsaw.
    Buzzsaw Synch has been set to synchronize continiously, however it only synchs when I actually log onto the server (I can also see from the Synch log, that it states 'service started' on the moment I log onto the server, so it does not seem to run when I am logged off from the server).
    Is there any additional settings needed to have it run continiously without to need to actually log onto the server?
    Thanks!
    Erik
    Please use plain text.
    Active Contributor
    Re: Buzzsaw Synch does not synch when I am not logged on
    10-31-2012 12:15 PM in reply to: Driel1973
    I have been looking into this issue myself, we are experiencing the same issue.  Right now i have an idea to use a vacant computer to sync all projects and just leave this pc on all the time.  Sorry i have no real answer for you.
    Employee
    eric.shipwash
    11-01-2012 01:26 PM in reply to: Driel1973
    Driel1973 wrote:
    Hello!
    Thanks!
    Erik
    The Buzzsaw sync service needs to be running in order for files to sync. The sync service will only run when you are logged into the machine/server that sync is installed to.  At this time it is not possible to sync when not logged in to the machine/server.
    Customer Support Analyst
    Autodesk Collaborative Project Management
