• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Buzzsaw
    Buzzsaw Login problem
    3546 Views, 6 Replies
    05-07-2010 06:21 AM
    trying to login into a buzzsaw account, using correct name and password and correct on the account details, I get an error:
    "Could not send a server request. network error: error code: 12057."
    Any suggestions from Autodesk as to what this might be?
    It occurs on 2 of the computers in the office but not on another 2, however they are all setup the same way and testing with things like admin rights doesn't see to make any difference.
    Please use plain text.
    Active Contributor
    Re: Buzzsaw Login problem
    05-07-2010 10:39 AM in reply to: ChuckEdwards
    Try this:
    Go to Internet Explorer>Tools>Internet Options>Advanced tab>Security options group and uncheck the box next to option, "Check for server certificate revocation">Restart IE
    John
    Active Member
    07-23-2012 03:29 AM in reply to: ChuckEdwards
    Just of curiosity, did this resolve the issue then? I can log on fine with this option 'checked'.
    I have people asking about this a lot, and usually advise it's an IT issue at their end, sometimes re-installing the latest application does resolve the issue. But it'd be nice to offer more advice.
    Employee
    07-23-2012 06:43 AM in reply to: andrew.grigg
    Product support has posted this as the solution:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15246533&linkID=9241337
    Thank you,
    Gregg Stanley
    Gregg Stanley
    QA Analyst
    AEC
    Autodesk, Inc.
    Active Member
    07-24-2012 01:54 AM in reply to: gregg.stanley
    Hi Greg, thankyou for your prompt and precise response. I advised our user to try this, but unfortunately it didn't fix the problem. They are using I.E.9 though, which I suspect may have something to do with it, but I have asked them to contact Autodesk Tech Support directly to resolve the issue.
    Employee
    eric.shipwash
    11-01-2012 01:56 PM in reply to: andrew.grigg
    The error is typically caused by an out of date security certificate, which is unable to update on their machine.  If the users PC clock set to the wrong date and/or year can also cause certificate issues, I would check the users time and date settings as well.
    Customer Support Analyst
    Autodesk Collaborative Project Management
    Active Member
    11-02-2012 01:48 AM in reply to: eric.shipwash
    Thanks Eric for the tip.
