• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Buzzsaw Developer
    Valued Contributor
    can't access markup DWF thru API
    1179 Views, 0 Replies
    02-19-2008 05:58 AM
    I currently use Buzzsaw 7.3 and I know there is a known problem with trying to access a "markup DWF" thru the API. See below. Does anyone know if this problem ever got fixed or will get fixed by Autodesk in a future Buzzsaw release?
    Problem: A "DWF" loaded in Buzzsaw can be accesses thru the API just fine but a "markukp DWF" can't be accessed thru the API. A "markup DWF" can only be accesses thru the API if it is saved from Buzzsaw to a local drive and then uploaded back to Buzzsaw. This downloading and uploading of the file, changes the properties of the file back to a "DWF" and can now be accessed thru the API.
    Please use plain text.
