• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Buzzsaw Developer
    Distinguished Contributor
    Getting a list of available projects
    1333 Views, 2 Replies
    08-28-2008 05:03 AM
    Is there a way to get a list of available Projects?
    I've tried.
    Dim PPprojects As PPResourceCollection
    Set PPprojects = PPsess.GetResource("SiteName")
    I get a type mismatch error.
    Please use plain text.
    Re: Getting a list of available projects
    09-03-2008 04:28 AM in reply to: GeeHaa
    I have also tried this.
    Dim PPProj As PPPROJECT
    Dim ppsit As PPSITE
    Set ppsit = New PPSITE
    ppsit.AttachSession PPsess
    Set PPprojects = ppsit.SubProjects
    I get a Subprojects method failed error after the above line
    For Each PPProj In PPprojects
    CBO_Projects.AddItem PPProj.Name
    Next PPProj
    Any help would be appreciated.
    New Member
    10-28-2008 07:09 PM in reply to: GeeHaa
    Hello geehaa,
    You can get the resources in a site by using the following methods.
    1. Using GetFolderContents methods in PPScripting
    If you set "https://webfolders.buzzsaw.com/sitename/test" to sURL,
    you can get all resources name in test folder.
    Dim oPPcol As IPPResourceCollection
    Dim oPPres As IPPResource
    Dim sFolderList As String
    sFolderList = ""
    oPPcol = oPPScripting.GetFolderContents(sURL, sUsername, sPassword)
    For Each oPPres In oPPcol
    sFolderList = sFolderList & ", " & oPPres.Name
    Next
    MsgBox(sFolderList)
    2. Using GetFolderContentsList methods in PPScripting2
    you can get XML file (Folder.xml) of all resources list in test folder.
    Dim oPPScript2 As New PPScripting2
    Dim fRes As String
    fRes = oPPScript2.GetFolderContentsList(sURL, sUsername, sPassword)
    Dim Fno As Integer
    Fno = FreeFile()
    FileOpen(Fno, "C:\Folder.xml", OpenMode.Output, OpenAccess.Write)
    PrintLine(Fno, fRes)
    FileClose(Fno)
    MsgBox("Done!")
    I recommend that you check sample programs in ProjectPoint API toolkit.
    You will be able to understand how to use the methods in the API samples.
