IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
what is shrinkwrap for
3 REPLIES 3
133 Views, 3 Replies
Hello all: I'm hoping somebody with a little extra time will tell me/us what
is shrinkwrap good for and what are the advantages/disadvantages of using
it. I've used ADT through all it's versions and have never used it. Am I
missing something? I've read the little info that is in the helpfile and
don't see what it does that wall styles don't.
If somebody could give the lowdown on Shrinkwrap I would appreciate it.
Mike Johnson
3 REPLIES 3
Don't get me started on shrinkwrap...
I don't know what it was designed for, but I can tell you how I used it in ADT2.
I would create a layer called 'SHRINKWRAP'. Then, in every wall style, I would
edit the display properties and assign the shrinkwrap to the layer 'SHRINKWRAP'.
I would assign SHRINKWRAP a color that make it plot heavier than the base layer
of WALL.
Then, I'd just freeze the SHRINKWRAP layer in the framing & electrical viewports
and, when plotted, the walls would be lighter than in my floor plan viewport. I
loved it!
However, in ADT3, there is a defect (ID 280268): shrinkwrap can't be
independently frozen from the wall layer. In other words, if you freeze
SHRINKWRAP from my scenario above, the entire wall freezes. This will supposedly
be addressed in the next service patch.
And that's all I have to say about that.
Scott.
> Thanks
> Mike Johnson
Scott Branch
scott@burnelljewett.com
Burnell & Jewett Architects
805.564.6074
www.burnelljewett.com
S.
you can however add a new Display rep that allows you to turn off the
shrinkwrap for ELEC.
etc..
> of WALL.
> loved it!
> Scott.
> > Thanks
> > Mike Johnson
> Scott Branch
> 805.564.6074
Nauman M
PC TroubleShooters
Need to easily Navigate to your Custom Content Folders?
Need Autolayering for Dimensions without going through Design Center?
Download the updated ADT Tools for ADT 2 & 3 at
http://www.mysorewala.com
Mike,
Shrinkwrap is intended to profile your walls in the same way an architect would
do it with a pencil. Make the outer linework heavier. ADT can also display
shrinkwrap for inner components (if you hav a big cavity for instance) - this is
shrinkwrap hatch.
Hope that helps.
Dennis McNeal
Architectural Resources
> Thanks
> Mike Johnson
