Autodesk Architectural Desktop 2007 & Prior
*H, Scott
Message 1 of 4 (220 Views)
stepped footing, brick shelf, etc
220 Views, 3 Replies
12-04-2003 08:29 PM
What's the best way to model a wall with a stepped footing? Do you change
the base elevation for a bottom justified wall & break the wall into pieces?
Then endcap the footing so it 'underlaps' the higher section... and endcap
the wall so it also underlaps the higher section... etc?
Is it possible to edit in place a brick shelf [height] on a wall segment?
*Rumple, Aaron
Message 2 of 4 (220 Views)
Re: stepped footing, brick shelf, etc
12-04-2003 10:04 PM in reply to: *H, Scott
I've always found drawing a short brick wall on the ledge simpler than
trying to edit a single wall to have a step. Particularly if the ledge will
have several different elevations. You could change the bottom offset in the
wall style to bring the brick down, but this works best when your wall has a
consistant brick ledge height.
...of course in Revit you just drag the bottom of the brick down. very cool.
"Scott H" wrote in message
news:C6E41F81891F73B21819BAAE5AA953AE@in.WebX.maYIadrTaRb...
pieces?
*StillwellK
Message 3 of 4 (220 Views)
Re:
12-05-2003 01:08 AM in reply to: *H, Scott
just edit in place , very simple
"Aaron Rumple" wrote in message
news:5E484A5B17D78CACC5999360D597DC5C@in.WebX.maYIadrTaRb...
will
the
a
cool.
change
> pieces?
endcap
segment?
*Rumple, Aaron
Message 4 of 4 (220 Views)
Re:
12-05-2003 08:28 AM in reply to: *H, Scott
I've found the edit in place tedious if you have a lot of walls to do and
the design is in flux.
"StillwellK" wrote in message
news:3779C9E821D662F9AAAAC22ADC244FB5@in.WebX.maYIadrTaRb...
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
