One other thing I forgot to mention...if you are using annotation that is
pulling project information (using property sets with project data and
formulas) - such as the level number as the first number of the room
number - and you've fully annotated the first construct...when you copy the
construct to the other levels...all your annotation is automatically updated
as the room number will be changed in the resulting constructs...say from
202 to 302 and 402, etc... and your door tag's will then also change to say
302A and 402A etc...
Cheers,
Julian
"Julian Gonzalez [Autodesk]" wrote in message
news:E85DAEC5BF74FB9F360CE68DAC1FA678@in.WebX.maYIadrTaRb...
> After you create the initial construct, simply right click on it (in
Project
> Navigator) and select 'copy to other levels' (or something like that...I
> don't have it open at the moment). Then select all the levels you want to
> copy it too and ADT will automatically copy it and create an additional
> construct for each level you selected. These should then come in at the
> appropriate elevation when you generate views.
> Also, if this is to represent a 'typical floorplan', you would then want
to
> first create your floor plan...or the typical part of the floor plan...as
an
> element. Then, create your first construct, x-refrence in the typical
> floorplan element. Now, after you copy the construct to other levels as
> mentioned above, when you want to modify the typical floor plan you simply
> take care of it in the element and it will be reflected throughout the
whole
> model.
> Cheers,
> Julian
> "v.valentijn" wrote in message
> news:B8D82C349E6756770AF4BDB370FFEC96@in.WebX.maYIadrTaRb...
> > I've been learning ADT for a while now and I finally get the feeling
> things
> > are starting to become clear...
> > There's one thing that I still can't figure out;
> > I want to draw up a single level and repeat it on different levels.
> > So I tried drawing this level in constructs > this level I defined as
> being
> > on 'level1' in the properties.
> > Then I made more constructs, dragged this first construct on them and
then
> > setting their properties to 'level2 / 3 / etc'.. So I would only have to
> > change something in level1 to change all the levels.. The new levels are
> > only XRefs of level1 right??
> > But the problem is - eventhough I redefine the construct to a new
level..
> > the drawing appears in the same place as the original, instead of the
next
> > level. So I manually moved up the construct in level2.. but STILL level2
> is
> > in exactly the same position as the original [level1]... WHY??!! Why
won't
> > this work??!! am I totally missing things here or is ADt just being
> > illogical on me here?
> > .. someone please tell me what I'm doing wrong.. or how to achieve what
> I'm
> > trying to do.
