Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
multiple install
2 REPLIES 2
183 Views, 2 Replies
multiple install
is it possible to install r14/s8, adt2i, viz 3 and adt3 all on the same
machine? every thing goes fine until i try to load the object enabler for
adt3 and it won't let me because it says it can't coexist with r14. at this
point if i try to open a r14 dwg with adt2i a lot of the stuff won't load
and a 2d dwg is loaded.
t.i.a.
mikr
2 REPLIES 2
Mike,
Install R14/S8
Install 3DS VIZ 3
Install all the VIZ 3 patches available at the Adesk web site.
Install the Viz 3"i" patch, if available.
UNInstall the Object Enabler 2.0 (installed by VIZ)
Install ADT 3.
See what happens.
Matt
mstachoni@beyerdesign.com
>t.i.a.
>mikr
Mike - if you have the full product on your computer, you do not need the
Object Enabler at all. Note that the "UNInstall" step that Matt provided is
critical. That's probably what's causing your trouble.
Bill Glennie
Autodesk AEC Market Group
"Matt Stachoni" wrote in message
news:oji75t46j5v7hevb6idv140qnmpvtj2h6f@4ax.com...
> Mike,
> Install R14/S8
> Install 3DS VIZ 3
> Install ADT 3.
