I'm not entirely sure that allows you to get the result back in mm
*AND* sq m. Isn't it either one or the other? Somebody please prove me
wrong in this, for years I've resorted to setting units to mm and then
mentally shifting the decimal point 6 places left to give me the sq m
result in area calcs. Not exactly slick but it works.
James
davo wrote:
> type 'units' on the command line and fill in the units you want
wrote in message news:5237091@discussion.autodesk.com...
> Hi!
> I like to use millimeter units for linear measurements and squaremeter units
> for areas.
> ACAD's drawing setup dialog box shows that this can be done but I do not
> know how to apply it.
> Whenever I use the area command, I always get the area values in millimeter
> units.
> Any input that may lead me to a solution will be highly appreciated.
> Thanks in advance,
> Phil
