It's actually "SHADEMODE" which is causing the text to disappear. If a
viewport's shademode is set to anything other than "2D wireframe", text in
paper space, which crosses the viewport, will be wiped out. You can tell is
a VP is set to 2D wireframe by looking at its UCS Icon (assuming it is
turned on). If the icon consists of simple blue lines and markers, than it
is 2D wireframe... if the icon is multi-colored 3D graphics, than it is not
2D wireframe. You can set this with the View > Shade menu, or the Shade
toolbar.
Paul Gold
PAUL GOLD CONSULTING
New York, NY
(212) 595-0171
paul.gold@att.net
"andreas foldager"
wrote in message
news:3C9FFEBB0BFC2CF6A6304B8BAAC48266@in.WebX.maYIadrTaRb...
> I have the same problem and want magic to happen too 🙂
> How exactly do you turn Viewport Hide Off?
> If you
> "Dennis McNeal - Autodesk" skrev i en
> meddelelse news:456FB741EC4A59919FB76C64A48FEDAF@in.WebX.maYIadrTaRb...
> > Turn off Viewport Hide & your text will magically reappear 🙂
> > Hope that helps,
> > Dennis McNeal
> > Autodesk
> > Building Industry Division
> > "Clyne Curtis" wrote in message
> > news:FD9F76D187CA7AB0C2757DC5944C6379@in.WebX.maYIadrTaRb...
> > > Here's a new one for me. I have set up a sheet with three viewports
in
> > > paperspace, each viewport showing different views of the same
floorplan.
> > > This floorplan is not xrefed into the current drawing. Here is the
> wierd
> > > stuff...when I place text over one of the viewports, it disappears
where
> > it
> > > crosses the vieport. Outside the viewport it appears fine, but looks
> > > clipped where it crosses the viewport. Text over all the other
> viewports
> > > works fine. Go figure...any help would be appreciated.
> > > Thanks,
> > > Clyne Curtis
> > > Brigham Young University
