what if you use the leader as you want to, and the dynamic block for the
bubble and the text and scale changes, plus move the bubble as the scale
changes. Make it so the bubble and text have an insertion point at the
bubble center point, the text is also middle-center justified, and by moving
the bubble as the scale changes, you keep the leader end point at the bottom
quadrant of the bubble.
Without actually doing it myself, would that work?
Or.....
Try your leader with a block at the end, but use Bob Kellerman's idea about
an elevation bubble for the grid bubble as your block.
Jack Talsky
wrote in message news:5238548@discussion.autodesk.com...
Yes, I thought about that, but the bubbles will scale about their insertion
point. Using a dimension or leader should scale about the correct point.
