Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
drawing window status bar missing in action
3 REPLIES 3
209 Views, 3 Replies
I opened a drawing this morning. The little "eyeball" drawing setup is
gone! The drawing window status bar is gone! I turned to the help files
for help, but help was not to be found.
How do I get the little guy back? Any clues? I tried the menu's and I've
right-clicked on everything I can think of. I just want to link to
vizrender, and it seems to be the only place that can be done, is in the
little eyeball..........
Please help if you can. I'm tired of searching.
bt
3 REPLIES 3
What version are you using? In ADT 2006, the Application Status Bar has an icon tray at the right side; one of these toggles the visibility of the Drawing Window Status Bar.
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006 & 2007 at home
You can type vizrender in the command line.
Also make sure you didn't accidentally set your drawing to clean screen...
Using 2005......I found it......thanks.
bt....
wrote in message news:5238289@discussion.autodesk.com...
David Koch
