IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
dimensions automatically explode
2 REPLIES 2
419 Views, 2 Replies
went i try to dimension anything the dimensions automatically explode, does anyone know how to fix this?? thanks
2 REPLIES 2
Type in DIMASO on turn it ON. Most likely it got turned off somehow. Hope this helps
If you are talking about AutoCAD dimensions [not AEC Dimensions], change DIMASSOC from 0 [exploded] to 1 [dimension objects created, but not associative to geometry] or 2 [fully associative dimension objects].
I have never tried this, and do not handle installations at my firm, so my knowledge on this is rather limited.
Using the network installation wizard, you can place some [all??] of those files in a network location, so perhaps you could do the same but use your 😧 drive in lieu of a network drive.
David Koch
Autodesk Discussion Group Facilitator
