Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
database between excel and autocad
2 REPLIES 2
157 Views, 2 Replies
Any tutorials that would explain how to create a database using dbconnect?
I have blocks that I want to connect with this database then to export the information into excel.
How would I do that?
tx
Erik
2 REPLIES 2
Erik,
I've never had the chance to fully explore AutoCAD dbconnect and the potential (if any) to create links with Excel sheets. What I have seen though seems pretty limited. Have you tried posting in the 'connectivity' newsgroup?
However, I do know of a program called Excellink 2000. I used the trial version recently whilst exploring database connectivity. It seemed to export attribute and block data to Excel sheets quite well.
Take a look at http://www.cadstudio.cz/excellink.htm
Unfortunately, our drawing information is stored within ADT property sets. Moving from one information type to another would be too labour intensive considering the sheer number of DWG files in our system.
We’re currently settled on a modified version of Peter Funk's 'ADT to Access' VBA script – although a lot of customisation is still required.
Good luck,
Paul Turnbull
Neighbourhood Services
South Tyneside Council
South Shields
United Kingdom
