• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Architectural Desktop 2007 & Prior
    *mike
    callout placement
    35 Views, 2 Replies
    10-15-2004 08:13 AM
    sometimes when i drag a view with a callout into a sheet via the pn i get the right sheet information but it is overlayed with a line of "#############" in addition to the sheet no and detail no. any suggestions how to fix this?
    Please use plain text.
    Distinguished Contributor
    Re: callout placement
    10-15-2004 08:43 AM in reply to: *mike
    If it is overlayed it sounds as if you have two fields, one on top of the other within your callout block?
    cc
    *mike
    10-15-2004 10:44 AM in reply to: *mike
    that's wat it was thanks "calfcreek" wrote in message news:1527292.1097855049951.JavaMail.jive@jiveforum1.autodesk.com... > If it is overlayed it sounds as if you have two fields, one on top of the other within your callout block? > > cc
