IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
adt 2007 xrefing
2 REPLIES 2
CTREVIZO
159 Views, 2 Replies
adt 2007 xrefing
regarding the new "EXTERNAL REFERNCES" tool palette; autodesk really skrewed up by not allowing to browse to repath an orphaned or an unreferenced xref or image in the case a file was renamed or then placed in a different folder or in the case of taking it between home & work; or could it be you can. i've trird to play with it to no avail.
2 REPLIES 2
in reply to: CTREVIZO
if you click on the missing xref and scroll to the bottom you can click
in the "Found At" box and a symbol appears on the right that allows you
to browse. is this what you mean?
> avail.
CTREVIZO
i happened to click everywhere else but that corner. "i tell ya"
