Hi Charlie,
Thanks for the great advice, I never would have figured that out. (I always
forget about that align command!)
Erin
"cbusa" wrote in message
news:4A9978F80F42370114AB18B98D657411@in.WebX.maYIadrTaRb...
> Erin create your ellipse on the world UCS plane. I took your ellipse and
> aligned it to crosshairs I created from 2 lines . Then convert the ellipse
> into a curtain wall. At that point you can use the align command again to
> place the curtain wall on top of (Nice Work!) the structure. If you turn
on
> visibility of curtainwalls in Plan Work Display rep you can confirm that
the
> curtain wall follows the shape of the ellipse by using rotate3d and a
> rotation of 90 degrees to make it flat in the world UCS XY plane.
> Charlie Busa
> Autodesk Independent AEC Consultant
> CADD Services
> PO. Box 25262
> Winston-Salem, NC 27114
> 336 945-0626
> "Erin" wrote in message
> news:E17707BBD76DE69063CAC33A0D24BBA3@in.WebX.maYIadrTaRb...
> > I'm hoping someone can give me a hand with a problem I'm having. I'm
> > attempting to create an elliptical window assembly and am not having any
> > luck with it. I want to create a window at the top of a circular
curtain
> > wall. The problem is that the curtain wall has been sliced at an
> angle-and
> > this seems to be confusing either me or ADT, I can't tell which. ADT is
> > giving me some weird results. I'm not all that sure it can do what I'm
> > attempting to create. I've posted a file in customer files under the
same
> > subject name. Would someone be so kind as to take a look at it and tell
> me
> > if it's possible?
> > Thanks,
> > Erin
