I'm shopping for an architect to design a ground-floor addition to the rear of our house with a roof deck above it in Albany, CA. I need my architect to produce the exterior drawings needed to get the design approved by the City of Albany. Then, I need them to produced detailed construction documents for the building permit. I will be the general contractor, hire out the electrical, plumbing and foundation and do the rest of the work myself. I'm looking for exact, detailed construction drawings.
We had a complete site plan done in AutoCAD back in 1998 and would like to input these files as a baseline to minimize the planning effort.
What should I insist that my architect have for AutoCAD software so that he can create these plans and reuse my old AutoCAD files?
Solved by David_W_Koch. Go to Solution.
THANK YOU, DAVID!
And thank you AutoDesk for making AutoCAD backward compatible to 1998.
