IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
What does my architect need to design our add-on bathroom and roof deck?
2 REPLIES 2
1184 Views, 2 Replies
I'm shopping for an architect to design a ground-floor addition to the rear of our house with a roof deck above it in Albany, CA.  I need my architect to produce the exterior drawings needed to get the design approved by the City of Albany.  Then, I need them to produced detailed construction documents for the building permit.  I will be the general contractor, hire out the electrical, plumbing and foundation and do the rest of the work myself.  I'm looking for exact, detailed construction drawings.
We had a complete site plan done in AutoCAD back in 1998 and would like to input these files as a baseline to minimize the planning effort.
What should I insist that my architect have for AutoCAD software so that he can create these plans and reuse my old AutoCAD files?
2 REPLIES 2
David_W_Koch
Any version of AutoCAD, from the one used to produce your site drawings or newer, should be able to open and use those files as a starting point.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
in reply to: David_W_Koch
THANK YOU, DAVID!
And thank you AutoDesk for making AutoCAD backward compatible to 1998.
