Hi Reid,
I was going to start a new thread with this question, but I'll ask it here.
Why don't my walls cleanup when I bring them together into a view drawing?
In my cleanup group definition I have the box checked for the walls to clean
up between host & xref, but with a View drawing, there are no "host" walls.
With the solution you just proposed, you would have to xref the "column"
construct into the wall construct as an attachment (which means you cannot
just drag it from the palette) to get them to clean up, right? Am I doing
something wrong?
Here is a "bizarre" thought:
Create a parking stall layout by using a curtain wall.
hehehe
"Reid M. Addis"
wrote in message
news:4849654@discussion.autodesk.com...
I think that Column and wall aren't going to clean up across xrefs but
someone else may know.
Here is a "bizarre" thought: in the column grid element file, make the
columns short, fat, walls.
Use a style with a lower Priority number than the walls that will pass
through them. and change the layer to A-Cols, or whatever.
Make sure that the cleanup groups are the same for the walls and "fake"
columns and that the endcap style allows for cleanups across xrefs.
This is strange enough that it actually might work! The only loss is the
ability to associate the columns to the grid, or for quick resizing.
Reid M. Addis
Registered Architect
Architectural Applications Specialist
Granary Associates
411 North 20th Street
Philadelphia, PA 19130
Ph. 215-665-7056
email: addis@granaryassoc.com
