IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Wall Styles & Clean up Groups
5 REPLIES 5
Doug
110 Views, 5 Replies
What is the best way of using these two? I am starting from scratch. Generally I use the "Solid Fill" wall style. Should I be setting up different styes for interior & exterior Walls? of just use the varible for thickness & heights? What are the advantages & disavantages?
I have created:
Interior Wall 8' with clean-up group IW8 (interior Wall 8')
Interior Wall 8' with clean-up group IW9 (interior Wall 9')
you get the idea... am I making too much work?
Doug
5 REPLIES 5
in reply to: Doug
Sounds like you're doing the least amount of work needed, actually. You
If you make int. and ext. walls different cleanup groups, they won't
clean up at all. I don't think that's what you want, at least it's not
what most want. For the walls to clean up correctly, the components of
the wall just need the same priority(which you can find by editing the
wall style). You can make different styles for int. and ext. walls, but
you don't have to make them different cleanup groups...make sense?
> I have created:
> Thanks
> Doug
Bob Kalinowski
Eberhard Systems, Inc.
in reply to: Doug
I does make sense....
in reply to: Doug
It all depends on how you work. I typically allow my interior walls to clean
up with exterior walls, when appropriate, so I don't separate them out by
cleanup groups.
Walls on different cleanup groups will NEVER clean up. You can also use
component priorities to control the cleanup more selectively (on a component
level vs. a wall level), keeping the walls on the same cleanup group.
Neither way is really more efficient than the other really. Again, it all
depends on what you are trying to accomplish and how much flexibility you
want between the two systems.
Please do not email me privately with technical issues
Matt Dillon
Assistant Moderator: Autodesk Discussion Forums
http://www.dccadd.com
"Doug" wrote in message
news:ef613d0.-1@WebX.SaUCah8kaAW...
I have created:
Doug
in reply to: Doug
Sorry to butt in... with the new wall merge command it is possible to
cleanup walls from different cleanup groups. (Not that I would do that for
each interior/exterior wall intersection though)
Never say never Matt.
-Chad
Matt Dillon wrote in message
<2124EDBA5B3D3C053A524659A2144CDF@in.WebX.SaUCah8kaAW>...
clean
>cleanup groups.
component
>Matt Dillon
>I have created:
>Thanks
>Doug
in reply to: Doug
Yeah, but, to split hairs, that wouldn't really be cleaning up, though,
right?
It's "merging". (ducking)
Matt Dillon
