Thanks for the input. I am working with a residential building type that
has a Pier and Beam foundation, sloping grade, intersecting retaining walls,
etc. As the exterior grades and intersecting retaining walls change, the
foundation walls change accordingly.
I'll try the "project" approach and see if I can make this work.
Todd
"Reid M. Addis" wrote in message
news:6B3026D00267AEAAF5DFAC1276B140B5@in.WebX.maYIadrTaRb...
> I don't believe the walls will cleanup if there baselines are at different
Z
> coordinates. Why are you doing this? There are other ways to get the
bottom
> or top of the wall at a different Z coordinate, such as the "Floor or Roof
> line" option where you can project to a line or pline, or auto-project
where
> you can project to another AEC object. You could also adjust the style
> setting under the Defaults tab, Offsets option, to use positive or
negative
> distances for the floor or roof line.
> Regards
> Reid M. Addis
> Addis Computer Consultants
> 1-800-841-4418
> http://www.addiscomputer.com
> raddis@addiscomputer.com
> "Todd Schnatzmeyer" wrote in message
> news:D53084F3B1E1267A86364CAD466B4733@in.WebX.maYIadrTaRb...
> > I have several conditions in my building model where intersecting walls
> have
> > different base "Z" elevations and overall wall heights. The "Wall Clean
> up"
> > does not seem to be working (have tried adjusting the cleanup radius but
> no
> > luck) Could anyone enlighten me about this?
> > Thanks,
> > Todd Schnatzmeyer-AIA
