IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Wall Cleanup Problem
3 REPLIES 3
271 Views, 3 Replies
I have a condition that I am unable to get the walls to cleanup properly.
Basically the condition consists of windows that are in a length of wall
that is basically the same width of the wall - where the window ends, the
wall turns the corner. I am getting wall cleanup errors in two of the walls
involved and I cannot figure out how to resolve the cleanup problem. Where
the wall is broken for the opening, all the endcaps should use the endcap
for that wall style in which the brick component returns back to the rigid
insulation. I have posted the drawing in the Customer Files group under the
subject "Wall with Window Cleanup Problem". If anyone has any ideas on how
I can resolve this, I would greatly appreciate the assistance. Thanks.
3 REPLIES 3
Bret,
I just found your post from the 12th, and I have posted a solution to CF.
Robert Connor
Thielsen Architects
"Bret Tushaus" wrote in message
news:C36A918D7BEE54BB4DB0BBFFE0CF1FD4@in.WebX.maYIadrTaRb...
walls
Where
the
how
Thanks for the reponse, what you did makes perfect sense...I should have
been able to come up with that.
I was wondering if you had any ideas on how I can make the endcap on the
horizontal window at the inside corner appear correctly? The brick from the
veritcal wall should really continue to the insulation at this opening.
However, if I try and apply a custom endcap to this opening to reflect this
condition, I get a cleanup error. Any ideas?
"Robert Connor" wrote in message
news:774C1B9B25E498785172AD868E71CD0C@in.WebX.maYIadrTaRb...
> Bret,
> Robert Connor
> Thielsen Architects
properly.
the
> walls
> Where
endcap
rigid
> the
> how
Bret,
I have not tried it, but you might be able to site the justification to the
inside face of the wall, the cleanup to the justification line, and then
create an endcap. I am not sure about this one. Whatever endcap is used it
can not interfere with the window, I know that much for sure. I have on
some similar situations moved or shrunk the window by 1/256" and had that
work. I am not sure that anything is possible for this condition. It is
probably something for a developer at Adesk to attempt.
Good luck.
Robert
news:36AA54223E9B06B3BC0A0B1D3D345B1A@in.WebX.maYIadrTaRb...
the
this
> > Bret,
CF.
> > Robert Connor
> > Thielsen Architects
> properly.
wall
> the
> > walls
> > Where
> endcap
> rigid
under
> > the
on
> > how
Thanks.
