IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Wall Clean up ADT 2006
3 REPLIES 3
jaroguy
186 Views, 3 Replies
am on ADT 2006. I am having problems with wall cleanups. I have a basic CMU-8 wall and in random instances it does not want to clean up. The graphline position is the wall justification line and I keep the cleanup radius set to 0". The graphlines are touching so it should clean up, right? Anyone have any suggestions? Thanks in advance.
3 REPLIES 3
in reply to: jaroguy
Post a ZIP file that contains an example of walls with which you are having trouble. Diagnosing cleanup issues via verbal descriptions is not going to work.
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006 & 2007 at home
Bubbaloo
Check elevations. They must be the same. Also ceck to make sure the ends of all walls are at the same elevation.
select all walls
set elevation to 0 (even if it shows as 0 in properties)
save close drawing
reopen.
Known bug in 2006 minute decimal place error.
