IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Message 1 of 12
557 Views, 11 Replies
Viz Render.
Viz render does not load. I get the startup screen then it loads plugins
then nothing. Wazup.
11 REPLIES 11
Message 2 of 12
Upon first run, there will be a dialog asking for
your prefered video acceleration. This dialog takes a few seconds to appear
and may be hiding behind other dialogs.
Try it again and let us know if that's
it.
jim
James D. Smell,
AIA
Building Solutions Division
Message 3 of 12
Nope.  It will say starting Viz Render,
Then the screen will flash the program then nothing.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"James D. Smell, AIA [Autodesk]" <discussion.autodesk.com> wrote in
message
href="news:3CD48E924603D79D45DF4201683BE93E@in.WebX.maYIadrTaRb">news:3CD48E924603D79D45DF4201683...
appear and may be hiding behind other dialogs.
it.
jim
James D. Smell,
AIA
Building Solutions
Division
Message 4 of 12
Is VIZ Render (VIZR.exe) running in the Task
Manager?
jim
James D. Smell,
AIA
Message 5 of 12
No.
Windows 2000 sp3,  Dell Inspiron 800, 866mhz,
256 ram.
message
href="news:B7467CB1CAEACF00C2383C7E9CF85AC6@in.WebX.maYIadrTaRb">news:B7467CB1CAEACF00C2383C7E9CF...
Manager?
jim
James D. Smell,
AIA
Building Solutions
Division
Message 6 of 12
Ric,
I noticed your under the minimum recommended 512 MB
of RAM.
Dennis
Dennis McNeal, AIA
Autodesk BSD
No.
866mhz, 256 ram.
in message
href="news:B7467CB1CAEACF00C2383C7E9CF85AC6@in.WebX.maYIadrTaRb">news:B7467CB1CAEACF00C2383C7E9...
Manager?
jim
James D. Smell,
AIA
Building Solutions
Division
Message 7 of 12
Would that prevent it from loading?
Maybe.
Ric,
MB of RAM.
Dennis
Dennis McNeal, AIA
Autodesk BSD
No.
866mhz, 256 ram.
wrote in message
href="news:B7467CB1CAEACF00C2383C7E9CF85AC6@in.WebX.maYIadrTaRb">news:B7467CB1CAEACF00C2383C7...
Manager?
jim
James D. Smell,
AIA
Building Solutions
Division
Message 8 of 12
Do you have anything else at all open? As Dennis points out, you are at half the min, rec, ram. If and when you do get it open, when you go to render: if not a freeze, maybe an overnight wait. Leaving aside Vizrender, I am NOT happy with my 512 ram for ADT 2004, although it seemed fine for 3.3. Bob
Message 9 of 12
No programs open.  In task manager nothing
appears in the Applications and vizr.exe will show up and then disapper in
Processes.  Before if flashes off there is still 120mb of physical memory
left.
Do
Bob
Message 10 of 12
Don't beat a dead horse (if you want my opinion). The Vizrender is going to be extremely annoying or useless on that machine as it sits, which is presumably a P3 (you didn't say) and may not have the proper video card (you didn't say). 256 more ram is almost cheaper than the time you have spend on this. Bob
Message 11 of 12
I will get the ram.  I just want to poke
around.  I know Matt Dillon is using the same machine with 512 ram and is
doing OK.
Is it now a bloody stump 🙂
Don't
Bob
Message 12 of 12
VIZ Render should run with 256Mb RAM.
Check the Readme and add the Environment variable
mentioned there.
Also, try starting VIZ Render using VIZR -H in the
command line, and then choose Software Z-Buffer as the display
driver.
Alexander
doing OK.
Don't
this. Bob
