Autodesk Architectural Desktop 2007 & Prior
*Matthews, Ed
Message 2 of 3 (62 Views)
Unknown Command
62 Views, 2 Replies
08-31-2000 10:09 AM
I am receiving a error "Unknown Command" when I use any of the AEC commands.
The AutoCAD part of the software is working, it's just the Architectural
part that is not. Can someone help in this problem before I have to
re-install the package again.
Ed Matthews
*Support, Tony - Americas Product
Message 1 of 3 (62 Views)
Re: Unknown Command
07-14-2000 12:00 PM in reply to: *Matthews, Ed
Ed
I would make sure that your support file search paths include the "\AutoCAD
Architectural\Programs" and the "\AutoCAD Architectural\Programs\PAT" path.
These are essential for the functionality of Arch Desktop. If you continue
to have problems, you should also review the sdsk.dfm file and make sure its
paths are set correctly.
Tony
Discussion Moderator
WW Support & Services, Autodesk
Discussion Q&A: http://discussion.autodesk.com
"Ed Matthews" wrote in message
news:ef2a8a3.-1@WebX.SaUCah8kaAW...
commands.
> Thanks
> Ed Matthews
Active Member
Re:
08-31-2000 10:09 AM in reply to: *Matthews, Ed
I have the same problem. I checked teh path and sdk.dfm file. they look ok to me. Any more suggestions? The message I get follows:
Command list interruption (6, 2).
Command list interruption (2, 3).
Command list interruption (3, 3).
error: null function
(CR_MNL)
(PROGN (CR_MNL) (ZZ_SDSK (QUOTE (PROGN (ZZ_LOAD "ZA" "leader" ZZ_LEADER ZZ#T
nil) (ZZ_LEADER nil 0.0 ZZ#T nil ZZ#T)))))
Command: Command list interruption (3, 6).
Command list interruption (6, 6).
Unknown command "SDSK". Press F1 for help.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
