Autodesk Architectural Desktop 2007 & Prior
*Decibel
Message 1 of 10 (2,624 Views)
Unable to load profile file.
2624 Views, 9 Replies
08-01-2006 06:12 AM
Hello all,
I am using ADT 2006 on Windows XP Pro. I also have IE 7 Beta 3 installed on
the machine (in case that has any bearing on my problem). When I open ADT
2006 I get an opening message saying "Unable to load profile file. Some
profile information saved in last session may not be restored." and then OK
button. I hit ok and ADT starts loading up. Then I get another message
saying "Unable to load tool catalogs. A required module is not registered
properly" and then OK button. I hit ok and ADT loads up but I dont have
access to the Tool palettes and Project navigator palette.
I am not sure how to tackle this problem. Any input would be useful. Thank
you.
Decibel
*Decibel
Message 2 of 10 (2,624 Views)
Re: Unable to load profile file.
08-02-2006 10:15 AM in reply to: *Decibel
I am sorry to see not a single response from anyone.
"Decibel" wrote in message
news:5254517@discussion.autodesk.com...
Hello all,
you.
Decibel
Distinguished Contributor
David_W._Koch
Message 3 of 10 (2,624 Views)
08-02-2006 06:44 PM in reply to: *Decibel
Well, be sorry no more. I do not mess with IE Betas, so I can not say whether IE 7 Beta 3 can be installed without affecting ADT 2006, but I would certain be suspicious about that.
You might try backing up any and all customizations you have made, then running a repair installation of ADT 2006 to see if that helps.
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006 & 2007 at home
New Member
iwan_satria
Message 4 of 10 (2,624 Views)
09-02-2007 10:01 PM in reply to: *Decibel
I am having the exact same trouble with you.
1. When I first click the AutoCAD icon, the error dialog shows up "Unable to load profile file. Some profile information saved in last session may not be restored"
2. I click OK, then the second error dialog shows up
"Unable to load tool catalogs. A required module is not registered properly".
I realize this error since this morning. I am suspicious with the Windows update patch. Does it have some kind of effect to AutoCAD?
BTW, I am using AutoCAD LT 2007, OS Windows XP SP2.
New Member
iwan_satria
Message 5 of 10 (2,624 Views)
09-02-2007 10:05 PM in reply to: *Decibel
Forget something =)
I have tried to reinstall AutoCAD LT 2007, but I still experince the same trouble.
New Member
katterine_angel
Message 6 of 10 (2,624 Views)
05-11-2008 07:31 AM in reply to: *Decibel
Hey did you solve your problem about AutoCAD 2007 when it says "unable to load profile file"? If yes, can you reply me I have the same problem..!
New Member
lcurle
Message 7 of 10 (2,624 Views)
11-08-2008 07:40 PM in reply to: *Decibel
uninstall your msxml and reinstall using the AutoCAD CD.
New Member
sajid_mukhtar2002
Message 8 of 10 (2,341 Views)
01-27-2011 08:56 PM in reply to: *Decibel
Hi all,
Reinstall the MSXML using Autodesk or AutoCAD CD and work. I have tried it. It workds great.
MSXML in the CD can be found in "Support" Folder. Install it and enjoy working with AutoCAD.
Sajid Mukhtar
tim
New Member
tim
Message 9 of 10 (1,351 Views)
04-03-2012 05:44 AM in reply to: *Decibel
Good morning, all,
I'm having this problem as well, only a little different.
Every time I start up AutoCAD 2007 LT, I get the "Unable to load profile..." error.
I hit Ok to close that window, and AutoCAD proceeds to load and function fine. It forgets what tool pallettes I had open and where I put them on my screen, but otherwise everything seems to be available and function just fine.
I had a problem with AutoCAD several years ago that made it non-functional. I did an installation repair which solved that problem, but created this one.
I have lived with this for years now because the program does actually work and the simple fixes didn't. It is really irritating, however.
Oh, here's one thing that doesn't work: I can't start AutoCAD by double-clicking on a .dwg file. It starts to open the program, gives me the above error, then over the top of that one, has a "FATAL ERROR: Unhandled Access Violation Reading 0x0020 Exception at 7c2431h". I have not even Ok'ed out of the first error yet. When I Ok that, It crashes out.
It creates an error log file that's not much more helpful:
04/03/2012 at 08:37:14.250 Drawing:
Thus I always have to start AutoCAD first, then open a file.
I have tried the fixes listed elsewhere here.
I have run xmlinst followed by regsvr32 msxml3.dll, both of which appear to be successful. However, nothing changes.
This is (and always has been) a single-seat, stand-alone installation on this physical computer, running Windows XP, SP3.
Any ideas?
New Member
1362744
Message 10 of 10 (1,301 Views)
05-01-2012 07:50 PM in reply to: David_W._Koch
I am really appreciate for all the information you gave. I am lucky to see them.
You are not logged in.
Announcements
Need installation help?
Ask the Community
