Create a Bent Column for Metal Buildings:
Variation of Tapered Column in application book on page 552.
Bent columns shapes along exterior walls usually consist of a vertical
exterior face and a tapered interior face.
Define a new member style called Bent Column. Edit the new member style
following the same steps per the Tapered Column for Start and End Shape
Parameters; then Make the following changes to End Shape Parameters for the
example above:
Relative to: Set to Start
Node: Set to 1
Z offset: Set to -2 3/4"
