Chris,
The hatching for slabs is only displayed where the body of the slab is
cut at the "Cut Plane Height". This height is an absolute value,
measured from the World Z=0 elevation, not relative to the slab
insertion point. This was done so that if you have multiple slabs, with
different base heights, the cut plane would go through all of them at
the same elevation. If you need a different cut plane height for a
specific slab, you can give it a unique display override.
Does that help?
Paul Gold
Autodesk Authorized Consultant
PAUL GOLD CONSULTING
New York, NY
(212) 595-0171
paul.gold@att.net
"cphubb" wrote in message
news:f0d9a3b.-1@WebX.maYIadrTaRb...
> I am having trouble getting a hatch pattern to display on a flat slab.
I have set all the display properties for the slab in plan view on,
defiened the pattern and set it to object. I have also messed with the
cut plane height all to no avail. Does anybody know what has to be done
to get hatch patterns to display on flat slabs?
> Thanks
> Chris Hubbard
