David,
First let me thank you for the heads-up on the updates! I attempted the
matrix solution to #1 before sending this out. Here is the issue: Each
Room can have multiple wall materials in it (i.e.: North wall is concrete,
south is gypsum, east is lightweight block, and west is RUBBER.) I knew of
no way to get a matrix to use more than 1 property declaration from the set.
I AM curious about things like this (no way to set up what we do here) and
wonder are WE doing things correctly? Should we consider changing the way
we show information if it doesn't seem to 'fit' within the software? Tough
choices sometimes.
At any rate, if you could comment about note #1, I would appreciate it.
Thank you,
Steve
wrote in message news:5142963@discussion.autodesk.com...
1. Consider using a matrix column, rather than individual columns for each
possibility, if a variable width schedule is acceptable to you.
2. Upgrade to 2007; this feature is new to the 2007 release.
See Header Overrides [second item] here:
http://architects-desktop.blogspot.com/2006/04/enhanced-property-data-features-in-adt.html
3. Upgrade to 2007; this feature is new to the 2007 release.
See List Definitions described here:
http://architects-desktop.blogspot.com/2006/03/enhanced-property-data-features-in-adt_31.html
David Koch
Autodesk Discussion Group Facilitator
