The chord length changes with the scale of the dwg. Initially, I believe,
its set up at 9" for 1/8" scale, 4.5" for 1/4" scale, etc. I did find out
that if you change the chord length in the revcloud options, say make it 8"
at 1/8" scale, close and reopen ADT, that chord length will still be 8".
You don't even have to save the dwg.
Neil
>>> martinnuttall 06/24/03 07:32PM >>>
How can you fix the initial chord length
and make it stick ?
Can you edit the file ?
Regards Martin
