For you residential users, check out the ADT Content newsgroup:
http://discussion.autodesk.com/WebX?14@@.f043177
news://discussion.autodesk.com/autodesk.aec.arch-desktop.content
Look in David Koch's thread "Simple Door Tags? [ADT 2004]". Sometime back he
put together some door tags REALLY close to what I see on a lot of
residential plans - where a 3'-0" x 6'-8" door, for example, would be
labeled "3068" (with the "0" and the "8" being a bit smaller). David did the
hard part - developing the formula to format the feet and inches properly. I
took it a little bit further and broke his single property up into four,
allowing me to create a tag consisting of four, independently sized
attributes. So, if you've been needing an automatic residential style door
tag that updates when you change the size of the opening, you've got it. You
can reverse engineer what David and I did and create the same thing for
windows as well.
Thanks to the ADT team for adding formula properties to the toolbox!
Matt Dillon
Assistant Moderator: Autodesk Discussion Forums
