Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Renaming ADT 3.3
10 REPLIES 10
Message 1 of 11
166 Views, 10 Replies
Renaming ADT 3.3
This is just an aesthetic/political thing.
We are implementing ADT 3.3 but for most users I just want to use it as 2002, ADT minus the menus.
What I would like to do is to have the application window say 'Autodesk 2002' at the top (As it does in the early stages of the loading process) instead of 'Autodesk Architectural Desktop 3.3'.
Any ideas would be gratefully received.
10 REPLIES 10
Message 2 of 11
You have to do it programatically by subclassing
the application window.
Best regards: Jimmy B
CAD manager at
href="http://www.pharmadule-emtunga.com">www.pharmadule-emtunga.com
Take
a look at  the trialversion of SmartPurger or download some freeware
at
http://jtbworld.vze.com
This
Message 3 of 11
Thanks for your response but that has gone a bit over my head.
If you could add a bit more that would be great.
Message 4 of 11
Then you or anyone else have to be able to program
it with VB or VC++ or the like. I don't have a 1 minute solution for it though.
I might be able to do it but then I have to have some hours for
it...
CAD manager at
Take
at
great.
Message 5 of 11
No programming needed.
The ARX modules that are loaded by Arch Desktop change the name. If you set
up Autocad to not load up the Aec Modules it will read Autocad 2002. Check
out the info on how to turn ADT into Vanilla Autocad at
http://www.stardsign.com/tips_and_tricks.htm
| Rob Starz
| Stardsign cad solutions
| iC - AEC Information Center
| www.stardsign.com/aecic.html
| free ADT and Building Systems tools
| ADTcadPac, ADTcadPacX and LayerX updates available!!!!!
Message 6 of 11
Doesn't work for me. Autodesk Architectural Desktop 3.3 shows up as soon as
a drawing is opened or a new drawing is created.
CAD manager at www.pharmadule-emtunga.com
Take a look at the trialversion of SmartPurger or download some freeware at
"Rob Starz" wrote in message
news:77F29C0487015673CBD7F24816565D16@in.WebX.maYIadrTaRb...
set
> | Rob Starz
Message 7 of 11
Huh....I thought I did this before...but I stand corrected.
head>
Thanks Jimmy.
| Rob Starz
Message 8 of 11
Hi again,
I now have a solution to this.
Tell me if you're interested.
CAD manager at
Take
at
This
Message 9 of 11
Garya,
The way to do this that worked for me is to create an new profile. In that
profile you first have to remove the AEC menu items. You do that via the
TOOLS > Customize... > Menu and then UNLOAD the AEC menu.
Name your profile something like "2002" and make it CURRENT.
Now go to the desktop on each computer and create a new AutoCAD Icon.
Rename it to A2k2 or whatever you like. Right click on the new icon and
select PROPERTIES. Now Select the SHORTCUT Tab and revise the end of the
Target Path from "/p adt.arg" (the "" are mine) to "/p 2002" or instead of
"2002" make it whatever you named your profile in ADT. They have to match
exactly.
Also while looking at that Target path, make sure it has only one path
listed....such as "C:\Program Files\Autodesk\ADT 3-3\acad.exe" /p 2002.
The quotation marks in this case are required because of the spaces between
some of the words. Note that there is a single space between the last " and
the /p, and also between the /p and 2002.
You can also revise the "Start in:" path while you are here so that the cad
operator will always start in the project folder. Saves them time browsing
the whole system for their working drawing.
I think that ought to do it.
I may have left out a step.
Good luck.
Jack Talsky
news:F361F2CDFD35DD747B389DCD5D728112@in.WebX.maYIadrTaRb...
> head>
> Thanks Jimmy.
> | Rob Starz
Message 10 of 11
Thanks for your responses.
I have no problem with setting ADT to run as Vanilla 2002. What I was trying to do was to make ADT say it is AutoCAD 2002 (in the top line, lefthand side) each time it opens or creates a new drawing.
Message 11 of 11
Guess I can't help you there. Sorry.
Why worry about it? If they can't see the ADT menu, why fuss anymore? how
many of them are going to actually see that line anyway and notice what it
says?
Jack
"Garya" wrote in message
news:f0a686a.7@WebX.maYIadrTaRb...
