Mazz wrote:
> Hello
> Is it possible to plot 2D elevations out in colour using ADT 206?
> Thanks, Mazz.
Sure, the process is no different than it is for vanilla acad.
How do you go about deciding your lineweights? By color or by the
lineweight options per layer?
Also, are you using CTB or STB (Color Tables vs Style Tables for
plotting). With STB you can mix and match color and black and white
lineweights in a very flexible manner. The same can be done for CTB's
but you must either choose you colors carefully, or define the
lineweights as BYOBJECT.
David Kurtz
Peckham & Wright Architects, Inc.
Columbia, Missouri
