• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Architectural Desktop 2007 & Prior
    Member
    Plotting Arch Desktop Blocks
    31 Views, 3 Replies
    02-04-2003 02:45 AM
    Can anyone tell me how to adjust the lineweights of blocks such as toilets, sinks, stoves, trees, etc.?
    No matter what layer or color assignment they have they always plot out as if they are on layer 0...which of course I inserted them....if anyone can help wth this I am greatly appreciative
    Please use plain text.
    Distinguished Contributor
    Re: Plotting Arch Desktop Blocks
    02-04-2003 04:16 AM in reply to: jbakaysa
    the blocks (i assume you mean mvblocks) where created on layer 0 with color, linetype, lineweight, etc. set to byBlock so that they'll take on the charteristics of whatever layer they're placed on. they should really be placed on a layer other than 0. xrefs are okay on 0 as are blocks that are made up of elements on specific layers but usually you'll want to put objects onto another logical layer (A-Fixt for plumbing for example). the layer key system will help with this...
    Member
    Re:
    02-04-2003 04:31 AM in reply to: jbakaysa
    ok...so instead of inserting the object with "0" as my current layer, I should make "p-fixt" (the layer I want the object on)the current layer before inserting any AEC blocks...? I will try it
    *Medina, Alfredo
    Re:
    02-04-2003 12:59 PM in reply to: jbakaysa
    No, that would be a waste of time. You don't need
    to browse for the proper layer before you insert a block. Go to Desktop >
    Drawing Setup > Layering tab ; select a layer standard and save as default.
    Now, insert anything from Design Center; all objects will be inserted in their
    assigned layer.
    Alfredo Medina
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    ok...so
