At the bottom left, just above the command window is a small arrow with a
circle around it, click that-go to the Layering tab and select the desired
layer key style-this should look familiar to you.
There are a few other functions on that arrow that you might want to
familiarize yourself with.
good luck
"Dana Jones" wrote in message
news:40572655$1_1@newsprd01...
> I've spent time with 3.0 and 3.3 but am just getting acquainted with 4.0.
> I'm working through Mr Aubin's book, have done the first part of the
> residential tutorial and made a copy of the first floor to work on as the
> second floor.
> When I draw walls on this second floor drawing, they come in on layer 0,
not
> layer A-WALL.
> I vaguely remember a Drawing Setup item in 3.3 that you had to change from
> "current layer" to the AIA scheme, but I can't find it now... can anyone
> help?
