IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Multiple select not active anymore
1 REPLY 1
116 Views, 1 Reply
All of a sudden, I can only select multiple items by holding the shift key.
Previously for example, when using the move command, I could select as many
items as I wanted, then hit enter and continue with the command. now, I can
only highlight and move one at a time. is there a toggle allowing me to
select multiple items at one time????
Thanks in advance.
1 REPLY 1
Right-click on the screen and select "Options" from the menu. Go to the
"Selection" tab. Make sure that the box for "Use Shift to add to selection" is
not checked.
> Thanks in advance.
