• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Architectural Desktop 2007 & Prior
    Active Member
    Move makes multiple copies of objects - regen fixes but some in wrong place
    172 Views, 2 Replies
    10-19-2011 06:35 AM
    I need some help. I have been using Autocad for 18 years and have never ran into this before. I grab a few objects to move them and it makes multiple copies of some of the object, almost like an array, then when i regen the "multiple objects" go away and some of the original objects are in the wrong place. I have checked latest video drivers, and system variables, but nothing has seemed to have been changed.  copy works fine. it is just the move command that is causing this problem.
    Please use plain text.
    pendean
    Re: Move makes multiple copies of objects - regen fixes but some in wrong place
    10-28-2011 05:53 AM in reply to: lownote1
    You are decribing GHOSTING, when your video card is not able to refresh fast enought to keep up with AutoCAD: what are your system specs and video card/driver? There is no "autoCAD" fix, you have to tone down Windows display settings, downgrade drivers, or change video cards to fix the problem.
    Dean Saadallah Blog | Facebook | RSS | Twitter | PINS
    Active Member
    11-02-2011 08:33 AM in reply to: lownote1
    Thanks for your help. Below is current video information. Please let me know if there are any other particulars you need to review. I sincerely appreciate your knowledge.
    NVIDIA System Information report created on: 11/02/2011 11:25:03
    System name: OWNER-COMPUTER
    [Display]
    1280X1024 85Hz Viewsonic G220fb
    Operating System: Microsoft Windows XP, 32-bit (Service Pack 3)
    DirectX version: 9.0
    GPU processor:  GeForce 8800 GTS
    Driver version:  280.26
    DirectX support: 10
    CUDA Cores:  96
    Core clock:  576 MHz
    Shader clock:  1350 MHz
    Memory clock:  850 MHz (1700 MHz data rate)
    Memory interface: 320-bit
    Memory:   640 MB
    Memory type:  GDDR3
    Video BIOS version: 60.80.13.00.05
    IRQ:   18
    Bus:   PCI Express x16
    [Components]
    easyUpdatusAPIU.DLL  1.4.28.0  NVIDIA Update Components
    WLMerger.exe  1.4.28.0  NVIDIA Update Components
    Nvlhr.exe  1.4.28.0  NVIDIA Update Components
    daemonu.exe  1.4.28.0  NVIDIA Update Components
    ComUpdatusPS.dll  1.4.28.0  NVIDIA Update Components
    ComUpdatus.exe  1.4.28.0  NVIDIA Update Components
    NvUpdtr.dll  1.4.28.0  NVIDIA Update Components
    NvUpdt.dll  1.4.28.0  NVIDIA Update Components
    NVCPL.DLL  6.14.12.8026  NVIDIA Compatible Windows 2000 Display driver, Version 280.26
    nvCplUI.exe  3.8.812.0  NVIDIA Control Panel
    nvWSS.dll  6.14.12.8026  NVIDIA Workstation Server
    nvViTvS.dll  6.14.12.8026  NVIDIA Video Server
    nvMoblS.dll  6.14.12.8026  NVIDIA Mobile Server
    NVMCTRAY.DLL  6.14.12.8026  NVIDIA Media Center Library
    NVOGLNT.DLL  6.14.12.8026  NVIDIA Compatible OpenGL ICD
    nvDispS.dll  6.14.12.8026  NVIDIA Display Server
    NV4_MINI.SYS  6.14.12.8026  NVIDIA Windows XP Miniport Driver, Version 280.26
    NV4_DISP.DLL  6.14.12.8026  NVIDIA Windows XP Display driver, Version 280.26
    PhysX  09.10.0514  NVIDIA PhysX
    NVCUDA.DLL  6.14.12.8026  NVIDIA CUDA 4.0.1 driver
    nvGameS.dll  6.14.12.8026  NVIDIA 3D Settings Server
