Morning Mark,
We will look into that program today. In addition, it *seems* that there are
*wide* variations in load times with McAfee running. The IT guys think it
might be related to "network traffic." I have Template and Content files,
plus some personal code files on a network drive which are involved in the
startup sequence. The times can vary from 10-30 seconds. The biggest
offenders seem to be the AecArchXM and AecSchedule programs. Do they do
things radically differently than the other arx and dbx code?
Reid M. Addis
Architectural Applications Specialist
Granary Associates
411 North 20th Street
Philadelphia, PA 19130
Ph. 215-665-7056
email: addis@granaryassoc.com
"Mark Taylor [Autodesk Support]" wrote in
message news:DDB184DB39449075011AD583992988B5@in.WebX.maYIadrTaRb...
> Reid M. Addis wrote:
> > I know I've been here before, but here goes again.
> > First of all, we are running the latest, 4.5 release of VirusScan.
> > Second, on a 1 ghz station, 256mb ram, Win 98 OS, with VirusScan
disabled,
> > ADT + all my other stuff loads in 15 seconds +-.
> > Third, even excluding *.dbx, *.arx, Aec*.*, *.lsp, C:\Program
Files\Autodesk
> > Architectural Desktop 3\*.*, and C:\Program Files\Common Files\Autodesk
> > Shared\*.*, ADT takes between 45 seconds to a 1 1/2 minutes to load. The
> > killers seem to be AecArchXM and AecSchedule.
> > Fourth, during initialization, the command area remains blank for about
10
> > to 15 seconds before it begins loading ARX and DBX programs. What is
> > happening during this period?
> > Fifth and finally: does anyone know how or what else I can exclude to
get
> > better start up performance from ADT. While one 45 second start up per
day
> > would be acceptable, we all know that ADT crashes multiple times each
day. A
> > 15 second wait to restart is acceptable. 1 1/2 minutes is not.
> Hi Reid,
> Unfortunately we do not have McAfee here to test, so I cannot check if I
get comparable performance
> issues when starting ADT (and whether excluding helps to any degree).
> The FILEMON utility (available from http://www.sysinternals.com) might
help diagnose whether McAfee
> is still accessing these files even though they are excluded from a check,
or may give some other
> clues as to what is going on. Am I right in thinking that when McAfee is
disabled the start-up time
> is 15 seconds? We have noted that with some virus checkers that when
disabled some aspects are
> *still* functioning, so the only way to be sure in certain situations is
to uninstall them.
> Mark Taylor
> Product Support, EMEA
> WW Support & Services, Autodesk
> Discussion Q&A: http://www.autodesk.com/discussion
